92A производство 2011>>2018 (K;L) Порш каен гибрид "Предупреждение гибридной системы"
26.04.2023, 21:19   #91
Сообщение от Akop Посмотреть сообщение
Подскажите please,может ли слабое давление масло на движке,оключать гибридную систему.
Нет...
18.09.2023, 20:55   #92
DReynolds
Нет...
Hi, writing from the USA. Yours is the only site I've been able to find any potential solution to my new (to me) Cayenne S Hybrid.
2011 Cayenne S Hybrid
VIN: WP1AE2A2XCLA92429
88,000 MILES
I am getting a RED Hybrid system fault warning nearly every time I drive it. I changed the 12v battery under the seat, which helped for a day, but fault returned. I have an iCarsoft Porsche scanner, and got the following codes. I can get better, more comprehensive ones in a couple days, if necessary, but am traveling, so I thought I'd shoot this out for now. I'm wondering if the high voltage AC cable is the issue. If so, I want to confirm part # for my VIN, and is this a DIY job (marginally capable) or should I take it to indy mechanic. Thank you so much, in advance, for your help and this great site.
DT Codes pulled:
000601 - generator fault, electric
008301 - fan control overcurrent
C120AB - Check high-voltage air conditioner compressor control unit
U111300 - Check A/C control unit faulty memory content
For what it's worth, I'm also having some instrument cluster comm issues. Doubt it's all related, but I thought worth mentioning. For instance, the back up alert system is not functioning, nor are several of the functions of the CDR system.
Thanks again!
18.09.2023, 21:12   #93
Сообщение от DReynolds Посмотреть сообщение
Hello, please write in Russian. This is the only language in which all technical issues can be discussed on this forum.
18.09.2023, 21:30   #94
https://forum.cayservice.ru/showthread.php?t=13475
нужен корректный код неисправности и блок управления (название) в котором он находится
название блока управления?
https://forum.cayservice.ru/showthread.php?t=15263
19.09.2023, 00:44   #95
DReynolds
Спасибо тебе за это. Я постараюсь перевести на русский язык следующие посты. Я уверен, что неисправность C120AB возникла в блоке шлюза. Я снова отсканирую коды, когда вернусь из путешествия через 2 дня. Я просто надеялся заказать кабель (при необходимости) во время моего отсутствия, чтобы ускорить доставку. Еще раз спасибо.
02.10.2023, 18:49   #96
DReynolds
Здравствуйте, я просто хотел сообщить, что я установил описанный выше кабель на Cayenne Hybrid, и он сработал. Я очень ценю всю информацию. Именно на этом сайте я определенно смог распознать и диагностировать реальную проблему. Я очень ценю все, что вы делаете для сообщества Porsche по всему миру!
Zdravstvuyte, ya prosto khotel soobshchit', chto ya ustanovil opisannyy vyshe kabel' na Cayenne Hybrid, i on srabotal. YA ochen' tsenyu vsyu informatsiyu. Imenno na etom sayte ya opredelenno smog raspoznat' i diagnostirovat' real'nuyu problemu. YA ochen' tsenyu vse, chto vy delayete dlya soobshchestva Porsche po vsemu miru!
11.12.2023, 22:41   #97
musta60
привет всем, у меня гибрид Prosche Cayenne, у меня сбой гибридной системы, я обнаружил код неисправности в гибридной си стеме
P178E00 : Function limit temperature -above limit value
может кто-нибудь помочь мне в этой проблеме
11.12.2023, 23:40   #98
Сообщение от musta60 Посмотреть сообщение
привет всем
Приветсвую!
VIN?
В каком именно блоке управления этот код неисправности?
11.12.2023, 23:52   #99
musta60
вин номер : WP1ZZZ92ZELA50682
приходит код неисправности
Силовая электроника высокого напряжения
12.12.2023, 21:28   #100
WP1ZZZ92ZELA50682
Cayenne S Hybrid Tiptronic (92AAM1)
P178E00
https://forum.cayservice.ru/showthre...843#post164843
hybrid, porsche cayenne v6 hybrid, блок, блоковый, вопрос, высоковольтный, гибрид, гибридная система, гибридный, замена, кабель высоковольтный, калибровка, ключ, контакт, мочь, нужный, обрыв, ошибка, передатчик, предупреждение, сервисный, система, сцепление, тема, штекер
[92A] Порш каен гибрид не заводится Пашка Вопросы специалистам 24 01.07.2022 22:57
Комплект "тормозов"(перед-зад) на Cayenne Turbo 2011 года Evgen Тормоза - механическая часть 11 13.05.2012 16:13
Порш "не кайен" Борис Болталка 12 25.01.2011 17:24
Крик души сотрудника МЧС или "Несовершеннолетним и слабонервным смотреть НЕ РЕКОМЕНДУЮ". СчастьеЕ Болталка 2 10.08.2010 14:10
