Куплю PCCB (керамические тормоза)
10.04.2011, 18:29   #21
Кост
Аватар для Кост
Porsche Ceramic Composite Brake Calipers / With a Set of Iron Rotors
Six-piston aluminum mono bloc fixed calipers on the front axle and four-piston units at the rear provide a high and constant brake pressure. The pedal response is fast and precise with only moderate input required.
This set is ideal for a big brake conversion or to replace worn out Calipers.
The pads and rotors have just 27,000 miles on them. They look like they have a lot of life left in them. Brake pads and rotors are consumables. They are included with the calipers and do not carry a warranty or guaranty of any kind.
We rarely see a set of calipers in this good of condition. Do not miss this opportunity to bid on this brake set.Please look closely at the pictures. The set photographed is what we will ship.
We make every attempt to satisfy your needs; however please do your research before buying this part, Refunds will not be issued for Fitment issues. If you run into any Problems Please contact us and we will help you the best we can.
We are the largest Porsche Dismantler this side of the world. In-house inspections are more than welcome and we can ship anywhere in the world!
If you have any other Questions please call us at 818-767-7243.
This price is outright and includes shipping anywhere in the continental US.
Эти?
11.04.2011, 01:29   #22
анархист
Аватар для анархист
Кост, я не силен в инглише,поясни пожалуйста о чем речь,что за контора и сколько они хотят за машинки ?
11.04.2011, 09:35   #23
xor777
Аватар для xor777
Сообщение от Кост Посмотреть сообщение
Эти?
Не, я эти не нашел. Это похоже как раз то что нужно, только с пробегом 27000 миль. А ссылку дай?
Меня только смущает фраза "With a Set of Iron Rotors" - это типа с металлическими тормозными дисками?
11.04.2011, 13:10   #24
Кост
Аватар для Кост
Porsche 911 996 GT2 Ceramic Calipers Set Brembo OEM | eBay
Добавлено через 56 секунд
http://cgi.ebay.com/ebaymotors/ws/eB...m=170623123229
11.04.2011, 15:00   #25
ДЖИНН
Аватар для ДЖИНН
Предлагали, просили 5000 Евро б.у из Польши , но правда года полтора назад-я отказался, не надо оно мне.
Если ничего не поменялось могу дать телефон человека , правда это Киев
, может решаемо и сейчас
11.04.2011, 15:35   #26
анархист
Аватар для анархист
Сообщение от ДЖИНН Посмотреть сообщение
Если не сложно кинь мне в личку.
11.04.2011, 15:37   #27
xor777
Аватар для xor777
Оно точняк! Только с металлическими дисками.
11.04.2011, 20:40   #28
анархист
Аватар для анархист
Сообщение от xor777 Посмотреть сообщение
Первый раз слышу о такой схеме,разве эффективно железные диски и керамическая колодка ?
11.04.2011, 22:19   #29
xor777
Аватар для xor777
Сообщение от анархист Посмотреть сообщение
Я тоже первый раз слышу. На фотках посмотри - они железные
12.04.2011, 01:46   #30
анархист
Аватар для анархист
они железные
Может банально крашеные суппорта ?
pccb, керамический
Porsche Ceramic Composite Brake (PCCB) Владимир Маркин Ходовая и подвеска 38 16.08.2016 19:14
