@Vladimir Markin,
Hi.. Cayenne S Hybrid 2012 WP1ZZZ92ZCLA91198
- Fault Hybrid System (only in yellow) and Fault Generator (in red).
- 99.9% Hybrid system is unengaged/disabled and HV battery won't support petrol engine.
- Fault Hybrid appears upon start or after a few Km/minutes of operation, while Fault Generator more sporadically.
- Vehicle runs fine, but (almost) only with petrol engine.
- Sometimes 12V battery indicates 11.5v, off the key for seconds and then goes to normal 14.6v for many days/kilometers of drive.
* A new 12V battery is installed.
* High voltage cable of AC compressor was changed in 2018.
* Clutch fluid has not bled properly yet.
Each diagnosis/reset occurs other codes:
Last check with Piwis gave: 000601, 000603, P0A7F00, P244200.
The strange and erratic behavior of the charging/electronics of the vehicle leads me to believe that we do not have a faulty generator/alternator here..
Any suggestions please..?
Thanks a million!
George
